DIY Valve retainer replacement with head in place
Old Apr 18, 2012 | 12:30 PM
  #101
vader1's Avatar
I can't find it in this thread:
Top dead center for cylinder 1, (and I think you can do cylinder 4 in this position as well?)
how much rotation on the crank from TDC for 2&3?
Old Aug 11, 2012 | 09:16 PM
  #102
sheel's Avatar
Started this job today... ran into some issues, in particular the spring compressor i'm using is garbage and i'll need to source another one.
DO NOT buy the Craftsman Valve Spring Compressor, it's a piece of junk that came apart while i was compressing the spring!!! A retaining pin and washer flew out as tensions was applied. Luckily I was able to find the pin... I hope nothing else fell in there.
Old Sep 14, 2012 | 12:41 AM
  #103
yamahaSHO's Avatar
Anyone use one of these to remove the retainers?
http://www.northernautotools.com/spe...e-engines.html
I have used this on my SHO in the past and it literally saved hours of work instead of using the bolt in spring compressor. I was able to puch the retainers off and then back on without fiddling around for a magnet or any other tools. My first go around on this car took 6-7 hours and I swore I would never do it again (My first go at it). Then when I went to build a motor for the car and bought brand new heads, I had to go through the process again. This time it probably took 20-30 minutes... The heads were not installed at the time, however, I don't think it would have added significant time if they were.
Old Sep 26, 2012 | 11:58 AM
  #104
madcowdk's Avatar
I hope this doesn't take this write up off topic but, what is the name of the tool that hooks to the compressor to pressurize the cylinder?
I cannot find it anywhere.
Old Sep 26, 2012 | 12:07 PM
  #105
yamahaSHO's Avatar
I believe mine came in my compression tester kit I bought from Sears years ago.
Old Sep 26, 2012 | 01:12 PM
  #106
madcowdk's Avatar
Awesome! Thank you. I do have access to one of those.
Old Feb 11, 2013 | 09:09 AM
  #107
phaeton's Avatar
Would it be wise to replace Valve Seals while doing this job? I don't have any symptoms that would make me feel like I need to do so, but if it would be a good idea for the sake of engine longevity, should I go ahead and do it while replacing the intake and exhaust side retainers and springs? How many of you guys have replaced the seals while replacing the retainers and springs?
Old Feb 11, 2013 | 05:32 PM
  #108
legend4life's Avatar
Perhaps guides/seats while in there as well?
Old Feb 11, 2013 | 07:15 PM
  #109
SouthDakotaS2K's Avatar
You could replace the springs and the seals if you like, however they are not as prone to failure like the retainers are. You will not be able to replace the valve guides or the seats while the head is on the car.
Old Feb 12, 2013 | 11:30 AM
  #110
yamahaSHO's Avatar
If you'd like to take the head off...
