DIY Valve retainer replacement with head in place
You can bring the piston to TDC to keep the valve from falling inside the engine. However, when you try to put the spring and retainer back on/keepers back in, the valve will likely drop a little making it very difficult. air is best to hold them up.
And as stated, you must use AP2 keepers with AP2 retainers.
It doesnt. You can do the job without touching the adjusters, and you will not disturb the valve adjustment settings in any way.
HOWEVER....when re-installing the cams and caps, you will be fighting spring pressure with some of the cam lobes (because the adjusters are not backed off) this is ok, but you need to go slowly and evenly when tightening down the cam cap bolts. Push the cams and caps down by hand, and go as far as possible by hand with the bolts.
Many people have broken the cam caps doing this without care.
Worst part is, you can't replace one cap. All 10 caps (5 upper and 5 lower) are a matched machined set.
HOWEVER....when re-installing the cams and caps, you will be fighting spring pressure with some of the cam lobes (because the adjusters are not backed off) this is ok, but you need to go slowly and evenly when tightening down the cam cap botls. Push the cams and caps down by hand, and go as far as possible by hand with the bolts.
what about late years EDM S2k's?
i'm talking about 2006 and up with 2.0L engines?
what retairnes these have?
wasn't it some TSB about pre 2004 retairners or something and Honda were supposed to use different ones for newer cars?
