Does it even help?
Old Dec 10, 2018 | 12:18 PM
Rockin S2K's Avatar
Question Does it even help?
Does this part work or is it for looks? I am confused how this would help. In theory it channels the air to the duck but does it really? Is there any real proof? Thank you.
P.S. I looked before posting and this question has not be brought up in some time.
Old Dec 10, 2018 | 12:46 PM
Chuck S's Avatar
Certainly looks wonderful.
Old Dec 10, 2018 | 01:53 PM
braytonia's Avatar
https://www.s2ki.com/forums/s2000-un...seless-849645/
Old Dec 10, 2018 | 03:42 PM
B serious's Avatar
The car has a factory radiator panel that does the same thing.
And a NA S2000 doesn't need any help with coolant temps. And if yours does, a bigger radiator would be a more useful buy.
This part is for looks...although it has a minor effect on radiator cooling.
I'm guessing it has a decent effect on intake temps, however? But its a guess. Do an experiment!
Old Dec 10, 2018 | 10:47 PM
Say Chi Sin Lo's Avatar
Yeah but... the 1 or 2 car enthusiasts within your circle of friends will be impressed for 5 minutes. Because, race car!
Old Dec 11, 2018 | 06:09 AM
Rockin S2K's Avatar
Thank you all for your helpful replies.
Old Dec 11, 2018 | 10:34 AM
s2000Junky's Avatar
Its part of a multi step process in reducing IAT which is hugely beneficial in this car with maintaining full optimum timing advance and mitigating heat soak. In order to make this the most functional, you need to cut out or remove the stock radiator diverter plate to get more air volume to pass through to the intake box opening, and a snorkel either bought or custom to channel that air from the grill and up into that intake opening. This rad plate with intake provision completely isolates the incoming air, helping to channel and focus that cool air into the box.
Old Dec 11, 2018 | 02:40 PM
alSpeed2k's Avatar
It definitely looks good. I think it makes a difference but it will be a very marginal difference. But yes, measure the temperatures before and after to see if it helps.
Old Dec 11, 2018 | 02:54 PM
s2000Junky's Avatar
I averaged about 40F drop in IAT overall with all said mods along with the coolant block off to manifold. If you have an 00-05 and extend the wiring harness from the stock IAT sensor located at the hot manifold and put it down to the intake like on DBW models, you will further realize more performance.
Old Dec 11, 2018 | 02:57 PM
623baller's Avatar
doesnt help with cooling but heard it adds 30 hp to the wheels
