does S2k differential has LSD
Old Oct 21, 2004 | 05:29 AM
unlimitedhonda's Avatar
Default does S2k differential has LSD
Well that's basically it though, just that one question... I have the AP1130, a 2002 model
thank you
Old Oct 21, 2004 | 05:50 AM
Stratocaster's Avatar
Yes. They all do. See pic below, #3 is the Limited Slip differential
Old Oct 21, 2004 | 07:04 AM
AusS2000's Avatar
It's Torsen T2.
It's not a conventional clutch pack limited slip but a rather clever design.
Old Oct 21, 2004 | 02:00 PM
sfphinkterMC's Avatar
actually, a stock S2000 does NOT have a LSD.
a torsen differential is a torque sensing differential, not a limited slip
Old Oct 21, 2004 | 02:02 PM
bluesaint's Avatar
and most of all, it's rather useless. Torsen is torque sensing activated, and tq and s2k isn't the most abundant.
Old Oct 21, 2004 | 03:53 PM
honda9krpm's Avatar
^ that's a good one
Old Oct 21, 2004 | 04:24 PM
AusS2000's Avatar
The real issue with a Torsen is that it is a torque ratio device. If one wheel has little traction it will transfer X times that torque to the other wheel. IE, if the ratio is 3:1 and the left wheel looses traction it will transfer 3X (or 75%, 3:1 is the same as 75%:25%) the torque to the other wheel.
But what happens if one wheel has 0 traction! 3 x 0 is still zero. That's why Torsens are not used in offroad vehicles (except with traction control or secondary locking mechanisms). Because one wheel off the ground would result in no torque to other wheels.
Shouldn't really be an issue with an S2000 as you'll never have a wheel off the road for long. If you do you've got much bigger problems. Even a slipping wheel has a certain amount of traction.
Old Oct 21, 2004 | 04:38 PM
thank you for the reply, just wondering there are fluid made for differential and fluid made especially for differential with LSD, so which one should I use?
Old Oct 22, 2004 | 02:32 AM
RACER's Avatar
If you read your owners manual, it says to use SAE 90 viscosity hypoid gear oil, API service classified GL5 or GL6 only in the differential. I have yet to see a GL6, therefore, you can use GL5.
Most of the peeps I know including myself, use Mobil 1 75w-90 Gear oil. It is a very good synthetic gear oil and is GL5 rated.
Old Oct 22, 2004 | 05:32 AM
Squeezer's Avatar
our diff is also only a LSD under acceleration. when you lift off the throttle its basically an open diff.
