dont know whats wrong :(
Old Mar 14, 2009 | 11:41 AM
1stuey1's Avatar
Default dont know whats wrong :(
I was just wondering i have just bought a 2000 s2000 which has a AEM inductionkit ( very big hard pipe) no other engine mods. on low revs usually 1st/ 2nd gear around town when accelerating sometimes it skips like mad!! it seems lik its jumping but i cant figure why! it was plugged in and no faults showed up, it was serviced in october by the previous owner inc plugs and all oils! can anyone PLEASE shed some light on this has anyone else had this happen to them...
thanks
Old Mar 14, 2009 | 11:43 AM
Olegator's Avatar
too broad.....might be map sensor, might be just that the car needs maintenance....
Old Mar 14, 2009 | 11:47 AM
1stuey1's Avatar
really? is it worth giving it a tap? am i just best giving plugs cleaning throtle clean out and see again?
Old Mar 14, 2009 | 11:54 AM
mlc's Avatar
mlc
If you are going to do the MAP whack here is the best way. http://forums.s2kca.com/showthread.php?t=19607.
Kevin
Old Mar 14, 2009 | 12:08 PM
negcamber's Avatar
How old are the plugs? If you aren't sure...you might as well change them out on a MY00.
MAP whack can't hurt.
Old Mar 14, 2009 | 12:13 PM
1stuey1's Avatar
plugs are 6 months old! what part number plugs should be in it? will do the map whack it cant hurt! very annoyin casue i just bought this car private and now this!
Old Mar 14, 2009 | 01:04 PM
negcamber's Avatar
Plugs should be the OEM NGK Laser Platinum PFR7G-11S...if you bought some crap Bosch platinums, then that could be your problem right there.
Old Mar 14, 2009 | 01:12 PM
1stuey1's Avatar
il do them anyways!! i just done the whack there havnt started will do later on hope it does it! the problem is there but only happens at 1500-2500 rpm mark not over! really frustrating
Old Mar 14, 2009 | 01:41 PM
cdelena's Avatar
Low rpm problems are very seldom the MAP sensor... don't get carried away hitting it.
Old Mar 14, 2009 | 02:00 PM
1stuey1's Avatar
any ideas what it could be
