dont know whats wrong :(
No CEL (check engine light) during all of this?
What fuel have you put in?
With "skip" you mean holding back?
So you're driving around in 1st or 2nd at 1500 rpm, then you floor it and then the engine holds back before the car accelerates?
When it does accelerate, it smoothly goes all the way to 9000 rpm?
How does the AEM filter look?
Clean?
I would start with the plugs too, as mentioned.
Get an OEM oil filter if the plugs were not OEM.
15400-PCX-004.
And check the trottle cable play.
Clean?
15400-PCX-004.
no cel light at all
just the normal unleaded sold over here noting else
yeah holding back when i put foot down
exactly
its perfect normally this only happens the odd time but when it does happen if i dont clutch it in straight away and gas it it will wont be smooth no!
Clean?
yea clean enough, its a huge pipe that comes from throttle body to the bottom of bumper
15400-PCX-004.
checked this seems alot off play when turned off but mechanic said thats normal ????
Thanks a mill
no cel light at all
exactly
Clean?
15400-PCX-004.
Thanks a mill
no cel light at all
exactly
Clean?
15400-PCX-004.
Ive never had a vac leak on my S, but on my camaro, the PCV valve hose was torn. It would run fine msot of the time for some reason, but when it got warm/hot/idle starts to drop, the Idle air control would try to bump idle, then it'd get too high, drop idle, etc etc.
When I fixed that, it drove perfectly fine.
I cant say for sure thats what it is, but cant hurt to check all hoses for tears/connections, etc.
If you had bad plugs, it would most likely report a misfire in your ECU. When my car had a plug wire loose, it reported it as a misfire... This also DOESNT happen @ WOT right?
Are your fuel injectors clean/not leaky?
---by the way...
I just read your new post. it sounds like you're talking about your engine bogging down! Its normal since we dont have much torque, and using a big fat air intake will usually drop your torque so it will make the problem more noticeable. If you clutch in, rev it to ~2K, and ease it in, its fine, right? its only when your RPMs' are low...
---by the way...
thats correct if i rev it high and drive off its fine but when im in low rpm its when it pops in! eg: coming up to traffic lights i am in third i shift to second its at 2000 rpm, the light goes green i acclerate it goes all weird then! d i make sense lol
