Drilled, Slotted Brake Noises
Old 10-06-2003, 07:47 AM
bazaar's Avatar
Default Drilled, Slotted Brake Noises
I've recently installed a set of SPUGEN drilled/slotted rotors. The install was pretty straightforward and I had no problems removing the OEM rotors and swapping the plated and drilled SPUGENs. I've noticed slight "clicking/whooshing" sound when braking. The noise has lessened as more miles are put on the rotors (approximately 1000 miles). Is this a normal sound, or is something else going on?
Old 10-06-2003, 09:59 AM
Sideways's Avatar
When I installed mine there was no noise noticed.
Old 10-06-2003, 03:34 PM
Alfredo's Avatar
I also installed slotted and drilled rotors with stock pads. I got the same noice you are describing, I still do. Some say it's the gases from the braking when the pads come in contact with the rotors.???
Old 10-06-2003, 03:58 PM
MajorHavoc's Avatar
I too have the same noise!!
I know it sounds odd but, you'll get used to it!!
Old 10-06-2003, 05:26 PM
Wesmaster's Avatar
Yes, same here. Clicking noise as the pad goes over the slots...take a little getting used to.
Old 10-07-2003, 10:29 AM
tenblade2001's Avatar
Did you change your pads????
I've done 2 sets of these and no noise, but I changed the pads too.
Old 10-07-2003, 10:38 AM
bazaar's Avatar
I was thinking that I should have changed the pads, but the car had only 9000 miles on it. It was a lot noiser at first but as the coating got scubbed off, the sounds got less and less. It's still there, but just barely. You think pads would make a difference? I had installed a drilled set on my 1988 RX-7, with new pads (they really needed to be replaced) and don't remember any sounds...
Old 10-07-2003, 01:08 PM
if you don't replace the pads you should atleast resurface them with some fine sandpaper.
Old 10-08-2003, 01:43 AM
honda9krpm's Avatar
does resurfacing the pad helps the noise problem?
Old 10-08-2003, 12:33 PM
jerrypeterson's Avatar
[QUOTE]Originally posted by Alfredo
Quick Reply: Drilled, Slotted Brake Noises
