drive shaft spacers
drive shaft spacers
so since im getting inner premature wear on my rear tires due to the fact that i have coilovers, and ive heard that drive shaft spacers are needed and not needed is there some people out there that experienced this and fixed it with some honest opinions thanx
Take a look at this thread:
https://www.s2ki.com/forums/index.ph...ic=490050&st=0
Spacers will not effect your tire wear. You may be getter increased inner tire wear due to the increased negative camber you are having to run to keep from rubbing...it looks like you have completely slammed the car.
yeah, the spacers will help your axels last longer and possibiliy cure that click from the back, but yould need to raise it or get a alignment done, but that will cause you to rub usually if your running anything aftermarket.
FYI
Dont launch car at track,if your slammed, the 7th time at 6k..you will break axle
lol
Originally Posted by S-Turn AP1,Feb 24 2008, 10:17 PM
Wow back again!!!
Might want to check your alignment
Originally Posted by AP_ONE,Feb 24 2008, 09:06 PM
yeah, the spacers will help your axels last longer and possibiliy cure that click from the back ...
Originally Posted by ToofastGPW,Feb 25 2008, 11:30 AM
FYI
lol
Spacers have NO BENEFIT AT ALL. Anyone who says otherwise has been dooped.
Originally Posted by RED MX5,Feb 25 2008, 02:04 PM
Read the thread Negcamber linked to above, then next time before posting, get your facts straight.
there is a bandwagon to follow :S
You dont like em, dont buy them!
