Driver's side rear lower than passenger side
Old Oct 25, 2007 | 05:58 PM
pantyraider's Avatar
Default Driver's side rear lower than passenger side
While removing my KW's, the driver's side rear was being a little stubborn, so I stepped on the rotor to give me enough play to move the coilovers out. I had to basically jump on it very hard in order for my gf to be able to yank it out. While doing this, I heard a very loud snap type sound.
Looking at both sides, the driver's side rear control arms defenitely droop lower than the passenger side. I also put the driver's side coilover back in to see how easy it was to fit it back in and I could put it in no problem (no pushing on rotor necessary). So, I"m wondering , did I break something or is i just my imagination? I checked bushings, ball joints, etc. They all look fine. Nothing is visibly broken. I'm wondering if maybe something snapped on the CV joint connecting the axle to the diff. Is that a possiblity?
Old Oct 25, 2007 | 06:10 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The torsion bushings simply snapped (rotated) to a new position. no harm done.
It will correct itself after a few good bumps.
Old Oct 25, 2007 | 06:21 PM
Thanks Bill! You were exactly the guy I hoped would respond!
Dizings2k
Aug 6, 2018 05:49 AM
Spazzmeister
Sep 27, 2014 10:52 AM
T-Rex06
May 20, 2011 06:43 PM
Imarriedmys2k
Aug 7, 2010 03:18 PM
esstwokay
Oct 23, 2007 11:07 PM
