Dropping fuel tank - what to do while in there
Old May 16, 2022 | 10:01 PM
Nate Tempest's Avatar
Default Dropping fuel tank - what to do while in there
I need to drop the fuel tank to replace the ORVR valve that's apparently stuck open. (This is on a 2006 AP2.) Are there any fuel filters or anything else it makes sense to change while in there? Searching parts I see a couple things:
16010-SDG-H00 Filter Set, Fuel
17516-SDC-E00 Filter, Fuel Pump
Also there's apparently a screen (the "sock") for the fuel pump, which I assume must be different from the filter above, as it doesn't look anything like that. Unless that's an AP1/AP2 difference?
So yeah, replace either of those, or would it be a waste? Anything else? Maybe should replace the charcoal canister too given it's been saturated with fuel due to the faulty valve? (Although I realize it's accessible without dropping the tank.) Or OK to just dry it out? Thanks.
Old May 17, 2022 | 04:50 AM
Kyle's Avatar
The first part number is the entire fuel pump carrier, which has filter media built-in
The second part number is the fuel pump sock you're referring to; there's no other filters in the OEM system aside from those.
Charcoal canister needs to be replaced once the charcoal becomes compromised & saturated. You can't really "dry them out". They have a service life, even when under ideal operating conditions. Just ensure that all of the hoses are free from any kind of blockages and what not.
Old May 17, 2022 | 08:05 AM
Thanks. So I'll replace the screen at least. Any point to replacing the fuel pump carrier with its built-in filters? It's only 45 bucks, so I figure might as well?
ss2ooo
Feb 15, 2021 05:27 PM
Z32MadMan
Dec 3, 2016 09:48 AM
learnerspermit
Apr 29, 2005 11:57 AM
dereks2000
May 17, 2003 06:37 PM
