Dropping fuel tank - what to do while in there
I need to drop the fuel tank to replace the ORVR valve that's apparently stuck open. (This is on a 2006 AP2.) Are there any fuel filters or anything else it makes sense to change while in there? Searching parts I see a couple things:
16010-SDG-H00 Filter Set, Fuel
17516-SDC-E00 Filter, Fuel Pump
Also there's apparently a screen (the "sock") for the fuel pump, which I assume must be different from the filter above, as it doesn't look anything like that. Unless that's an AP1/AP2 difference?
So yeah, replace either of those, or would it be a waste? Anything else? Maybe should replace the charcoal canister too given it's been saturated with fuel due to the faulty valve? (Although I realize it's accessible without dropping the tank.) Or OK to just dry it out? Thanks.
The second part number is the fuel pump sock you're referring to; there's no other filters in the OEM system aside from those.
Charcoal canister needs to be replaced once the charcoal becomes compromised & saturated. You can't really "dry them out". They have a service life, even when under ideal operating conditions. Just ensure that all of the hoses are free from any kind of blockages and what not.
The first part number is the entire fuel pump carrier, which has filter media built-in
