Dual to Single mod
Old Oct 10, 2007 | 11:33 AM
duanet85's Avatar
Default Dual to Single mod
could you take a dual exhaust and make it single? i have the skunk 2 set up in dual, just wondering if its feasible to use a plasma cutter and cut off the driver side exit in a way so the left over metal folds down over the exhaust and weld that up. i mean i know its possible, but beneficial? i would like a single exhaust and considering the cost of one, and since i already have a dual...didnt know if that would work, just thought i'd ask where theres more knowledge to be had... thanx guys.
Old Oct 10, 2007 | 12:03 PM
Sinji's Avatar
yes you can make it a single as long as you can weld. usually single gain more top end as long as the piping diameter is correct
Old Oct 10, 2007 | 12:11 PM
duanet85's Avatar
well the piping is 60 mm. from my understanding you dont want much bigger if you are N/A/. no problem with the welding at all.
Old Oct 10, 2007 | 01:03 PM
NVMY4N's Avatar
If your comfortable with cutting and welding on your exhaust I say do it.
Old Oct 10, 2007 | 01:20 PM
2poor2mod's Avatar
go for it and post some pics of the process and finished product
Old Oct 10, 2007 | 03:31 PM
duanet85's Avatar
I'm gonna have to figure out how to post pics. I won't be able to do it for about two weeks. I will post when I start to do it so keep tabs on the post
Old Oct 10, 2007 | 04:45 PM
ridestrt's Avatar
I had an invidia dual I converted to a single. car doesnt look anytihng like this anymore and I dont still have the exhaust but here you go
http://www.youtube.com/watch?v=Kvj-YIK_kR8
Old Oct 10, 2007 | 06:34 PM
ShocK's Avatar
60mm is too small if your looking for gains, isnt that smaller than stock? 62/63mm? It would loose weight and be louder probably.
Old Oct 10, 2007 | 07:37 PM
duanet85's Avatar
i think you'd be surprised at how many after market exhausts feature 60mm piping...
Old Oct 11, 2007 | 11:39 AM
mister x's Avatar
I'd carefully cut one leg of the dual at a straight part of the pipe, with a Dremel preferably to get a very clean cut. Then instead of welding, use a cap which is clamped on to see if it works. If it doesn't, should be easier to go back to dual. BTW, I think you'll find the section you capped will act like a Helmholtz resonator and reduce some drone.
