Dyno Results in Conflict
I've seen many postings of dyno results on threads on dyno results. I'm curious that my results conflict with many that I've seen here. What I've seen are results in the 195 bph range.
I had my totally stock S2K dyno'd about four months after I received it with about 5K miles on it. The only difference was a change to Mobile 1 Synthetic Oil - which obviously wouldn't make a difference in the world. Here were my results:
75.8 degrees
Measured:
Max Power = 205.5
Max Torque = 138.3
Corrected:
Max Power = 201.7
Max Torque = 136.5
Any ideas or am I reading the results incorrectly?
If my reading is in question, I'll be happy to scan the data and post for someone to correct my reading.
75.8 degrees
Measured:
Max Power = 205.5
Max Torque = 138.3
Corrected:
Max Power = 201.7
Max Torque = 136.5
Originally posted by krazik
it's all about how much the ECU is retarding you because of heat soak and other factors.
FF2Skip
Mar 12, 2007 05:58 AM
