e-manage question
i'm thinking about getting an e-manage but was wondering what greddy harnesses etc i would need to purchase? can anyone running an e-manage help me out? thanks.
depending on what you have done to the car, it might not be worth it.
If you just purchase it, you can use it as glorified vafc. but you'll want to have the programming tool so you can adjust more than the 5 set points. That's an extra 100 buck on top of the emanage.
If you're not using forced injection, you don't need to add fuel. The ECU is good at that and pulling fuel will be sufice. However if you are FI, you will probably want to have the extra injection plug.
If you want to pull or advance timing, you'll need the timing harness.
However, you will want to have the harness made up for you so you do not have to figure out what wire does what under there and splice into the car wires, you can do a google and search for PNP harness. Pasquel from frog did a wonerful job on mine. However figure about 150 ish plus shipping for the harness PNP set up...
So like I said you might not want to go the emanage rout depending on what you did to the car. If it's NA get a vafc. If it's FI get the emanage. And save yourself a lot of time get the PNP harness either way. Well worth it!
I don't want to seem like a materialistic bostard here but I have a Greddy E-management for sale if you'd like. I used it for 3 months and I have all the harness execpt the one you'd need to connect it to a computer (You'd have to purchase the connector separately even if you bought it new). It is pre-tuned for S2000 with turbo with 7psi of boost (If you don't have same or similar setup or your weather is completely different from Maryland [87 degree] than you'd have to get it re-tuned). I'm asking $150 and you'd have to pay for shipping.
With that said. Greddy E-management is a decent system for low boost or N/A motor (as use in fuel management). During when useing this product you'd feel jerks and hesitations (because it is a piggy-back system) and you won't be able to tune it as preceise as a SMU. But it won't be as near the price you'd have to pay to get a AEM EMS (AEM EMS would be an over-killed if your running under 12psi of boost or N/A motor).
Tuner
Tuner
