easy question
really low on oil and have some part mineral 10W40 is this ok to top up with, car done 1400 miles
please let me know it it will do any damage, im pretty sure it'll be ok, but just like to check!
cheers
cheers
went to the local gas station, told that the 10W30 is unusual - tried a couple of places and settled for 10W40 - will get some from the Honda dealers for next top-up
is about 10% above Min
is the Oil for our cars really that rare??!
There have been several threads stating that 10W30 is hard to find in Europe. That is surprising, because it is probably the most common grade of oil in America. 10W40 is fine for most cars, but I wouldn't use that thick of an oil for going to Vtec.
ok, put in just enough to keep the car fine for a while. about 0.5L, and will get hold of the proper stuff next time.
strange 10W30 is more popular in the US then UK, are the cars different???
heard that replacing with fully synth gives slightly better performance, is this true? and when should it be done - around 5k??
cheers
cheers
Just as Honda decided to do the oil jet bolt recall for European cars (and nowhere else), your oil companies must think that due to your driving style, a slightly thicker oil must be better.
Although synthetic should allow your engine to function with a bit less resistence from synthetic fluid, some have observed that it also makes VTEC less pronounced. I have not noticed this but who's to say that it doesn't happen in some cases.
The manual (and most board members here) recommend staying away from synthetic till about 10K miles (or 15K Km) when it is considered that the engine has reached the end of its "proper" break in period and when any oil consumption (if present) has tapered off.
The only place (that I know of) to get 10w 30 mineral oil is from a Ford dealership in the UK.
I used that for top up until my first service (12mths - 3507 miles). I am now using 10w 40 semi synth Shell Helix with 250ml of the molybdenum added.
Andre
Mar 23, 2001 05:35 AM
