?ECU
Old Apr 28, 2008 | 04:13 PM
1320performancefreak's Avatar
Originally Posted by SenderGreen,Jan 14 2007, 02:06 AM
JDM ECU = No immobilizer
JDM ECU = No OBD2 (pretty sure)
JDM ECU = Maybe tuned a little different. I'm think the JDM F20 has higher compression ratio.
Mine have a obd2 port on my jdm s2k
Old Apr 28, 2008 | 07:58 PM
SenderGreen's Avatar
So a JDM S2000 has a DLC. I noticed in another thread you said you fixed the CEL from a missing air pump. Assuming that's the same JDM car. Did you pull that code from the DLC with an OBD2 scan-tool?
I'm actually kind of surprised the JDM cars would have the air pump. I suppose if a JDM car can store a DTC for the air pump, they must have OBD2 to some degree.
Having a DLC and being OBD2 compliant are two different things however.
Old Apr 28, 2008 | 08:02 PM
yes i pull the code using a regular obd2 scanner from pep boys. and i pull the 2 codes from the JDM ecu. and the car pass CA smog at regular smog station with the obd2 cable plug in to the obd2 port
Old Apr 28, 2008 | 08:13 PM
Upon further invstigation OBD apparently comes in flavors.
OBD II (California ARB)
EOBD (European OBD)
JOBD (Japanese OBD)
A JDM car should be JOBD, not OBD2.
Anyway, that's what I read.
Correction: Most Japanese cars built in this time frame are OBD2 compliant (around 2001 and up I guess)
http://tunertools.com/forums/showthread.php?t=58
What does the sticker under the hood say?
Thanks
EDIT: Nevermind, I'm still curious as to what the sticker say's though.
All gasoline engine cars sold in the EU since 2001 are fully OBD2 compliant
All diesel cars sold in the EU since 2004 are fully OBD2 compliant
Old Apr 28, 2008 | 08:26 PM
sorry the car have a new hood because of
Old Apr 28, 2008 | 08:28 PM
I see.
Thanks anyway, I still learned something new.
darkknight
May 19, 2011 12:30 PM
chris_barry
Australia & New Zealand For Sale and Wanted
Sep 15, 2010 02:22 PM
chikin tities
Jul 23, 2008 07:26 PM
futomame
Aug 12, 2003 05:27 PM
