Ecu error code
Old Jun 4, 2007 | 11:34 AM
Honda_Mad's Avatar
Default Ecu error code
Hi guys
Recently my ecu through error code P-1067 PCM internal malfunction. I had a VAFC spliced in the ecu harness. It first throw a map sensor error code. I check the connections and discovered the throttle signal wire was loose. Disconnected the VAFC and reset the ecu. Then got a Error code P-1067
Funny thing is the car still drives perfectly normal, goes into vtec and pulls hard till redline. I am confused - Is my ECU busted?
Old Jun 4, 2007 | 03:13 PM
Honda_mann's Avatar
that might be a honda dealer tech answer espically with bulletins being posted on techlink. Or it might go away with adding a few miles too it if it drives ok??
s2000_x
Dec 30, 2011 09:51 AM
c32b
Nov 21, 2010 09:32 PM
ce-ce
Dec 10, 2009 11:16 AM
MechaGodzilla
Apr 4, 2005 10:33 AM
tru
Oct 1, 2004 02:37 PM
