ecu question
Old Feb 18, 2003 | 04:38 AM
dereks2000's Avatar
Default ecu question
does the stock ecu automatically advance timing if you put better octane gas in it? I am thinking about running 100 octane.
Old Feb 18, 2003 | 04:56 AM
Sunder's Avatar
As far as I know, no it doesn't.
It has a fixed map, and can only retard when it senses knocking, not advance when it senses higher octane fuel.
Old Feb 18, 2003 | 06:12 AM
Gernby's Avatar
Former Sponsor
If you go to a higher octane fuel, you should reset your ECU. If your ECU has been retarding timing, it will continue to do so for a while if you don't reset it. After resetting it, the engine will run strong, but the idle quality will suck for a day or two.
Old Feb 19, 2003 | 09:13 PM
dereks2000's Avatar
how do i reset the ECU?
Old Feb 20, 2003 | 06:03 AM
BlackS2000Turbo's Avatar
I have to agree with gernby, that will likely yield the best results for you. The ECU will only advance / retard timing based on intake air temp, knocking, air quality (density). You can reset it by pulling the fuse by the drivers kick panel just rear of the ECU. I don't recall the fuse number but will look it up tonight when I get home if someone hasn't posted it for you by that time.
-BS2KT
Old Feb 20, 2003 | 06:15 PM
reds2's Avatar
I think it is fuse #25.
Old Feb 20, 2003 | 06:54 PM
Sideways's Avatar
Check out the library. https://www.s2ki.com/article/articleview/5/1/15/
lukedon
Aug 19, 2007 02:18 PM
fastmonkey
Aug 23, 2005 03:16 AM
Detroit_Doc
Jul 1, 2005 03:11 PM
RARE M5
Apr 30, 2003 01:45 PM
