Electrical connector to bypass solenoid valve
Where can I buy this electrical connector that connects to the bypass solenoid valve part of the vacuum tank system? I looked on majestic and oem honda diagrams on electrical connectors but it's not on there. Is there something I'm missing please help?! The screw holding the sensor (bypass solenoid valve) on the Kn fipk intake, popped off so it fell and the pulleys shredded it and the electrical wire connector exposing the wires and I don't know if it's completely damaged but the p2 connector really took a beating. I am going to use some electrical tape to hold it together and put it all together once the new bypass solenoid valve comes in (#2 On vacuum tank system) , but if I'm still throwing a P0411 CEL than I'm going to have to replace the connector. Please help!
I think the only way to get what you need is to find someone parting out a s2000 that would be willing to cut that connector outof their harness. That connector might be used for other things on other Hondas so you might find what you need at a local junkyard with a little searching.
It's the same connector used on the VTEC oil pressure switch, the Air Temp sensor in the intake manifold, etc. I'd just run to your local pull-a-part and cut one off and splice it in. Worst case scenario, if you convince me it's worth my time, I'll ship you one of mine.
Phantom327
Apr 13, 2017 11:11 AM
Boostaholic
Jun 17, 2007 01:31 AM
GoFaassttt
Oct 6, 2004 05:12 PM
