Electrical problem
Old Nov 18, 2009 | 01:28 PM
arkkornkid's Avatar
try cleaning the throttle body, the butterfly can get gunked up and cause stumbling/stalling. If it's not in bad shape, then maybe a TPS issue?
And do what Kirpich suggested.... these are the simple first things to try
Old Nov 18, 2009 | 01:46 PM
Chow-bot's Avatar
you still have the supercharger installed right??
if so you may want to mention that.
running aem ems if i am correct
Old Nov 18, 2009 | 01:52 PM
dj-'s Avatar
dj-
you are correct
Old Nov 18, 2009 | 02:36 PM
Chow-bot's Avatar
Yea that changes everything and you are better to post in the FI forum
Old Nov 20, 2009 | 07:10 PM
Kirpich's Avatar
If you're FI with the EMS, I suggest you have a tuner look at your map. I have the same problem, where it's idling up and down, and when it's hot in the summer, it even stalls. The problem's in the tune's temperature compensation tables.
Get a wideband and start looking at the AFRs when it's doing it.
Cranking problem could be because of CPS or Camshaft position sensor going bad or losing good connection (loose connecor). Check all 3 of them. These things are doable before spending any serious cash on pulling the head, etc.
How is your compression? check that, you can do it yourself by either buying or loaning a compression tester gauge. I bought one form Harbor Freight, it's garbage. Try autozone or Advance auto parts, or whatever you have in Canada.
You probably should also do a leakdown test.
Double-check your grounds. Very important. Don't forget the one on the back of the head (between the head and the firewall), and the one by the ECU in the footwell. Let us know.
Old Nov 21, 2009 | 07:06 AM
SgtB's Avatar
It sounds like a AEM cold start issue. Not uncommon.
Ryan9
Dec 16, 2011 10:03 AM
PaulF
Apr 17, 2010 09:28 AM
dj-
Nov 19, 2009 07:20 AM
M2K
Aug 26, 2009 06:10 AM
GDM S2K
Oct 18, 2005 05:24 AM
