Emange install question
Old Aug 31, 2004 | 11:14 PM
home13oy75's Avatar
Default Emange install question
When wiring the emange up I noticed from previous diagrams that a lot of ppl are using B1 for 12v switched power and B10 for the ground.
Since I am not using a Frog harness - hard wiring straight to the ECM harness, can I just use the fuse box for the switched power and the ground? It would be less wires that I nees to splice into in the harness. Thanks!
Oh and is everyone still pulling fuse 25 for the emanage or was that just a urban legend?
Ray
Old Sep 1, 2004 | 01:21 AM
AusS2000's Avatar
You should be fine using switch and direct power from the fuse box.
Old Sep 1, 2004 | 06:46 AM
home13oy75's Avatar
Thankf for the info.
Anyone know if the pulling of fuse 25 still being used?
Old Sep 1, 2004 | 02:34 PM
AusS2000's Avatar
That really depends on your set up. If you are modifying mid-range parameters a long way from what the ECU expects then it will try to tune them out. That's why you need it to reset frequently.
But if most of your changes are top end or mild then you don't need to remove the fuse.
Soul Coughing
Nov 10, 2013 03:35 PM
Suzuka_Joe
Jul 20, 2011 03:28 AM
pipedreams96
Mar 6, 2010 11:03 AM
Shftat9k
Mar 5, 2007 09:46 PM
