engine check light on after a clutch repair
Old Jan 18, 2014 | 04:39 AM
a.sunnucks's Avatar
Default engine check light on after a clutch repair
Hi everyone.once again my s2000 is being temperamental. I've just had the clutch and flywheel fitted and once I picked it up the engine management light came on. I took it back and they did a diagnostic check and they said it was a knock sensor and cleared the fault but it came back on the way home. The engine sounds and goes fine v tec engages no problem. After a bit of searching on the Internet it seems it could be the crank angle sensor or a knock sensor. Or maybe something else? Is there an easy way to check these or if they where broken during the installation is it and expensive repair? If you think it could be something else all help is appreciated.
Thanks in advance.
Old Jan 18, 2014 | 04:59 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
They broke your knock sensor while accessing the upper starter bolt.
Very common occurrence by those not familiar with the car.
All you have to do is touch the harness with the extension and it will break the top from the knock sensor.
Old Jan 18, 2014 | 05:10 AM
a.sunnucks's Avatar
Ah Thank you do I have to worry about driving it until it can be sorted since my garage would be open again till Monday. Where abouts would I find the knock sensor? Is it a easy job to do your self? Sorry for bombarding you with questions I just want her running right again . Thanks again
Old Jan 18, 2014 | 05:31 AM
Billman250's Avatar
Top Answer: 1
I have found it easiest to remove belt, belt tensioner, belt tensioner mounting block and such to access knock sensor. Then use an open end wrench to remove.
It's on left side of block, dead center between cyls 2 and 3.
Not easy but not bad if you are good with tools.
Cruising is fine, I'd avoid hard driving until you change it.
Without it, the ECU cannot hear spark-knock and you can damage the engine.
Old Jan 18, 2014 | 05:45 AM
a.sunnucks's Avatar
Thanks a lot for your help there's just so much about this sort of thing on the Internet.
Well I'll give it another check over and take it back to the garage on monday since if they broke it I shouldn't have to fork out for it. Since they just had my trousers Dow for the clutch fitting.
Old Jan 18, 2014 | 05:53 AM
a.sunnucks's Avatar
One other things is there a easy way to check if it's the actual sensor or the wiring that's been damaged
Old Jan 18, 2014 | 05:58 AM
Billman250's Avatar
Top Answer: 1
I assure you 100% that the green plastic top portion of the knock sensor got broken off of the steel portion. It's extremely brittle, especially after a long life of heat/cool cycles.
Your wiring is fine
s2kbtos
Jul 5, 2010 06:04 PM
f20cpower3
Apr 15, 2010 01:14 PM
Dan Norton
Oct 9, 2009 06:16 AM
S2KCHRIS305
Oct 20, 2008 12:10 PM
2_and
Jan 16, 2005 09:46 AM
