Sticky Throttle
Old Jan 18, 2014 | 04:35 AM
moches's Avatar
Default Sticky Throttle
Hey guys, I parked my car outside in the rain all weekend and came back to a sticky throttle. Whenever I step on the gas, there's a kink before it smoothly engages. Does the pedal or throttle cable just need some lube or maybe it needs to be re tightened? The problem happened over a short two day period, and I think the rain and this problem are unrelated as I've parked it outside many times before. Thanks.
Old Jan 18, 2014 | 06:01 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That is usually the throttle plate sticking in the throttle body bore.
Usually cleaning the edges of the plate will cure it. (clean it with a rag, do not spray anything into the TB)
If not, a micro adjustment will be needed to the stop adjuster to compensate for wear.
Gernby
Jul 21, 2016 05:59 AM
cheddaboy
Aug 29, 2015 11:55 AM
The Prophet.
Jun 23, 2015 10:18 AM
JimmyB
Jul 18, 2007 11:07 AM
bunjimobile
Aug 17, 2004 01:39 PM
