Engine Check light/ and Vibrating
Hey guys i have an 07 s2000, and love the car.. ive had it for about over 3 years now. Recently I've been on the freeway and after 65mph my back and car starts to rattle and vibrate i dunno why. Also sometimes when i hit vtec and I'm redlining the car, the engine check light will flash fast about 3 times and then it will go away. Its very weird i have no idea what the problem might be. Now recently i did put back on my stock exhaust and deleted my cat, so right now I'm running a test pipe all the way out, would that be the reason?
I always thought a blinking CEL= shut down engine pronto
...Um...and not to be a peckerhead, but this isn't a CWL (Check Wheels Light)...its something going wrong with the motor. Pull the code while its still available to be read.
A flashing check eng light should be picking up a cylinder misfire. I would check for dtc's. If your car is lowered my assumption for the vibration would be: tire balance, tires worn uneven (alignment), or getting sideways too much and wearing the tires excessicely. Or if you car sits alot, possibly flat spots.
