engine clicking questions
Old Aug 1, 2010 | 01:21 PM
Justin Yoo's Avatar
Default engine clicking questions
how will i know if the ticking is from the valves, valve retatiners, or TCT? if its the valves, do i just get a valve adjustment and it should be good?
will driving the car normally or WOT when the engine is clicking bad?
also when i blip the throttle in neutral position, the revs build up, come back down to normal idle speed, and then about 1.5-2 seconds later the engine shakes quite noticably. it definitely isnt a normal shake. what could that be?
Old Aug 1, 2010 | 03:04 PM
RedSex2k's Avatar
The clicking and the shutter are probably unrelated. The clicking is likely the valves needing adjustment if it hasn't been done for a while. If louder (card in bicycle spokes noise) it's the tct. You can probably cure the shutter with a MAP whack, found on this site or by disconnecting your negative terminal to reset the ECU. May be the summer heat too.
Old Aug 1, 2010 | 03:18 PM
Justin Yoo's Avatar
thanks redsex2k but to me, the valves and the TCT sound the same to me.. is there any way to diagnose it to be sure?
Old Aug 1, 2010 | 03:47 PM
akirhol's Avatar
The valves and the TCT do not sound the same. A bad TCT is a very distinct sound:
[media]http://www.youtube.com/watch?v=EVS-JLfmTnc [/media]
Old Aug 1, 2010 | 05:11 PM
Justin Yoo's Avatar
is it safe to drive the car when the valves need adjusting? is it safe to drive it hard?
Old Aug 1, 2010 | 07:30 PM
RedSex2k's Avatar
Many people who report engine ticking are just reporting a fairly normal sound for the engine. If the valves are a bit on the loose end of the tolerance, you should be fine to keep driving on it. My rule of thumb is that preventative maintenance is the best maintenance, so I'd say budget maybe $250 and get do both. Then you won't have to worry about either for a good while.
Old Aug 1, 2010 | 09:58 PM
Justin Yoo's Avatar
Thanks RedSex2k good information!
Uncle Fester
Jan 8, 2008 09:26 AM
sliderz28
Mar 12, 2007 05:34 AM
FRM
May 14, 2004 11:03 AM
