Engine Coolant Drain Bolt
Old Jun 10, 2025 | 01:22 PM
  #21
windhund116's Avatar
Originally Posted by cosmomiller
That explains why my stock car has remained tight over the years. The hose look and feel brand new. Nothing like the American cars of the 60s and 70s.
They grabbed the mule and cut some hair off the mane. They mixed heavy grease in it and shoved it into the hole with a screwdriver until they could do no more. Filled it up with water and away we went back to San Diego. It held pressure until we got a new radiator!
They stopped using donkey tails a while back. The mules protested.
Old Jun 10, 2025 | 03:29 PM
  #22
Slowcrash_101's Avatar
Originally Posted by Car Analogy
Careful, as you're likely changing ratio of coolant vs water over time.
It might not be a surprise that coolant molecules are more complex than water (h2o), and therefore larger in size. So most of the evap through silicone hoses is water.
So if topping off with premix 50/50 coolant, over time you've got less and less water. Since cast majority of cooling comes from water, not coolant, you're cooling capacity is declining.
You'd need to sometimes top off with just water. But how often would require testing, like w hydrometer.
I lose like 100ml every 6 months. Not really worried about changing the ratio of 1.75 gallons of coolant with 1.2 liters of 50/50 over a 5 year period. Maybe im at like 45/55 water to coolant ratio? Next year when I replace it I'll be back to exactly 50:50 and you can sleep well.
2009 s2k
Apr 26, 2026 02:34 PM
szkf22c1
Jul 24, 2012 10:58 AM
madenot
Jan 15, 2011 04:59 AM
S2000Matt
Aug 26, 2010 12:25 PM
Legal Bill
Apr 21, 2010 05:40 AM
