Engine Cradle Shifted? (Updated resolved issue)
Old Mar 22, 2010 | 12:44 PM
PistolPete76's Avatar
Default Engine Cradle Shifted? (Updated resolved issue)
I'm rebuilding a car that was curbed on the front driver side. I put new lower control arms, and spindles on it. I have some snap on camber/caster gauges. I use these to get it close to make sure everything is square.
Well it’s not getting square. I'm getting 0 deg maximum on the driver’s side. and -1 maximum on the passenger side.
Does anyone know if it’s possible to shift the engine cradle on these the S2000. Is the engine cradle aligned, or does it use self aligning bolts that do not require the cradle to be aligned to the frame during installation. Thanks
Pete-
Old Mar 22, 2010 | 12:52 PM
Stratocaster's Avatar
It is. both the front and rear can be shifted slightly.
I have seen uppers slightly bent, as wells as lower slightly bent too. So it may not be the subframe.
Old Mar 22, 2010 | 02:53 PM
Okay cool...
I just got done measuring the front subframe. Its shifted to the right about 1/4". Im not sure if its shifted or just bent in on one side. I'm going to try to loosen the bolts and move it over.
I guess if that doesnt work, I'll have to buy a new one. More fun!
Old Mar 23, 2010 | 03:45 PM
Stratocaster.... You were right on...
I jacked up the front end loosened the engine cradle bolts. With my cast/camber gauges attached one on each wheel. I lightly tapped the right side with a soft blow hammer until both sides where equal. I tapped on the lower part of the rotor.
When doing this make sure your zero out all your alignment bolts first. Then loosen the cradle, and adjust it left to right. I was almost a whole degree off from left to right.
Now with the alignment bolts zero’d I’m at (-.48 front left) (-.49 front right).
Keep in mind this car hit a curb so hard it broke the lower control arm, and destroyed a spindle. So for anyone contemplating replacing an engine cradle try this first.
Pete-
JeffreyMartin
May 30, 2012 09:34 AM
Tech7427
Nov 6, 2010 05:34 PM
Bibbs
Apr 21, 2008 08:45 AM
Standing Room Only
May 30, 2006 09:58 AM
essess
Dec 30, 2005 06:28 AM
