Trouble removing s2000 transmission
Old May 29, 2012 | 08:17 PM
JeffreyMartin's Avatar
Default Trouble removing s2000 transmission
I ran into a problem while removing the transmission. The driverside top bolt is in a crazy spot and I'm using about 3' of extensions to get it, but the impact won't take it off at full force. Is there some way to get to it?
Old May 29, 2012 | 08:56 PM
9MMSWORD's Avatar
to get to that bolt you must rock the transmission and use a 1/2 air gun.
Old May 30, 2012 | 12:31 AM
AP1Theory's Avatar
I never did a transmission/clutch change, but I did do an engine swap without utilizing a car lift(only using jackstands and a jack) I ran into the same problem as you did(because you have to take the transmission out before you can pull out the engine). It was an easy task accessing all of the hard to reach transmission bolts from the top of the engine bay after taking off the engine off the engine mounts and slightly lifting up the engine and transmission up a little with an engine hoist. Make sure you don't break the knock sensor while taking out the top 14 mm starter bolt. Oh, and after taking out all bolts, make sure you pull out that fork that connects to the throw out bearing.
Old May 30, 2012 | 06:08 AM
speedjunky01's Avatar
The extensions drop the power of the gun
You have the sub frame dropped right?
I got both off with a ⅜ ratchet and a 6" extension without a problem
Old May 30, 2012 | 07:05 AM
GSteg's Avatar
3' is wayyy too long. Youre better off attaching the extension to a breaker bar
Old May 30, 2012 | 09:34 AM
Mannyfresh's Avatar
Use a breaker bar.have someone hold the socket in so you don't strip the bolt.
zagamuffin
Sep 10, 2012 02:22 PM
Tech7427
Nov 6, 2010 05:34 PM
wonderd
Apr 29, 2009 08:59 PM
skibum
Sep 29, 2007 05:50 PM
rudeS2k
Dec 30, 2005 07:19 AM
