engine fire -> damaged harness
Old Jan 31, 2007 | 07:04 PM
Slows2k's Avatar
You aren't the 1st person to set a car on fire, and burn this exact part of the harness.
You want to tell us who changed oil last and what filter was installed?
Old Jan 31, 2007 | 07:22 PM
SenderGreen's Avatar
Ya, maybe all the people who pop up in other threads saying "hand tight is fine for your oil filter" will see this. I have posted in at least 2 maybe 3 threads saying to torque down oil filter to spec, only to have 6 or 8 people chime in after me saying "no you don't really need to worry about it, hand tight is fine".
I have seen Billman250 trying to warn people against hand tightening filters for this exact reason before. He speaks from first hand expierience, whereas I just regurgitate what I have read.
To the original poster. I'm not saying you hand tightened your oil filter, or trying to bash you for it if that's the case. I just wanted to rant on the subject. It could have also been a seal/gromet stuck to the block from the old filter (or so I have read). It seems it was most likely one of the two. Anyway, best of luck on the repair.
EDIT:OP, How did you pu the fire out? Did it flare up when you popped the hood? Seems like it didn't get too out of control. Did the fire "flame out" on it's own while you were driving?
Old Jan 31, 2007 | 07:34 PM
Slows2k's Avatar
http://forums.s2ki.com/forums/index.php?showtopic=84019#
Funny thing happend back in 02 and 03
Old Jan 31, 2007 | 08:16 PM
addisonc's Avatar
This was my 1st oil change, and I ****ed it up. I was using a genuine honda oil filter, but the problem was.. The old filter's gasket was still attached to the engine. I put on the new filter with the old gasket still there resulting in leak.
Please warn everyone about this. Check for old gasket.
Old Jan 31, 2007 | 08:18 PM
addisonc's Avatar
Originally Posted by SenderGreen,Jan 31 2007, 08:22 PM
EDIT:OP, How did you pu the fire out? Did it flare up when you popped the hood? Seems like it didn't get to out of control. Did the fire "flame out" on it's own while you were driving?
Well, the fire started in the engine while I was driving. When I stopped and open the hood, I saw the fire. I panicked (thinking that the car was gonna explode) and ran as far away from the car as possible. But, I should have closed the hood first. Now, I have a burnt harness? help?
Old Jan 31, 2007 | 08:38 PM
Spec_Ops2087's Avatar
Well atleast you can man up to it
Plus, you learned a lesson, always check the gasket of the old oil filter so this never happens again
Old Jan 31, 2007 | 11:57 PM
Thanks, I'd never actually read that thread.
That's kinda funny, not necessarily a bad first instinct. So, no real flare up, and the fire went out on it's own?
[QUOTE]Well atleast you can man up to it
Old Feb 1, 2007 | 02:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That is very odd...IF it was a PCX filter you took off, it's not the kind of filter that leaves the gasket on the engine.
Put a 15400-PCX-004 filter on there, and tighten it with a wrench. This filter is different than most filters. You cannot use gasket compression to hold it on, it must go metal to metal.
So take the coil cover off and see how far back its burnt. I'll check my parts harness tonight, I definitely have that part, you will still need to have it soldered. good time to learn
s2k_Doug67
Aug 15, 2016 08:52 AM
kap
Apr 25, 2013 07:46 PM
roi
May 23, 2008 10:34 AM
