Engine Harness Connectors HELP!
Old Nov 26, 2024 | 08:42 AM
maxpro's Avatar
Default Engine Harness Connectors HELP!
I purchased an engine from a reputable salvage yard that have full video of the engine running and provided a guarantee to go into my S2000 (2002). I purchased the S2000 with a blown engine and I'm in the middle of an engine swap. The issue is that they damaged the wiring harness when the pulled the engine. It looks like they crushed it with setting the engine on the shipping pallet. I need to see if I can find these three connectors. Any and all help will be appreciated. I have checked with Ballenger Motorsports and they said they didn't have any of the three. I'm new to the forum and I thank you for your help.
Old Nov 26, 2024 | 09:10 AM
engifineer's Avatar
Ouch. A Solutions may be a source to get used ones but they may want to sell an entire harness vs cutting one up.
I know a friend said they use findpigtails.com to find OEM style connectors. Maybe an option but I have not ordered from them
Old Nov 26, 2024 | 09:28 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Can you use the original engine harness?
Old Nov 26, 2024 | 09:38 AM
maxpro's Avatar
Thanks for the lead findpigtails.com. I will check them out.
Old Nov 26, 2024 | 09:39 AM
maxpro's Avatar
That is my backup plan. I will still need to identify the pins used, some are damaged. If you have any suggestions on the pins used that information would be welcomed. Thanks for the quick response.
Old Nov 26, 2024 | 09:42 AM
engifineer's Avatar
Oh, if you still have the original harness, then yes just use it. I am confused on the pinout question though. If you have the original harness from your car, you can just plug it in right? Just completely remove that harness and use the one that was on the old motor in the car.
Old Nov 26, 2024 | 10:01 AM
Billman250's Avatar
Top Answer: 1
Did you pull your original motor yet?
Old Nov 26, 2024 | 10:15 AM
spider2k's Avatar
https://www.corsa-technic.com/item.php?item_id=1343
Here's the first one, check for the rest.
Old Nov 26, 2024 | 11:33 AM
maxpro's Avatar
I purchase the car with a blown motor. Someone put a turbo on it without rods and one of the rods (3rd hole) decided to exit the block. I'm trying to put the car back to original and I'm not sure how hacked up the harness is. I will look this weekend. I have the engine ready to come out of the car with the exception of two bolts to the bell housing.
Old Nov 26, 2024 | 11:34 AM
maxpro's Avatar
It is ready to come out. 2 bolts and it is out.
