Engine hesitation while idling
Old Mar 29, 2011 | 06:27 PM
  #21
yourboysoap's Avatar
Ok so i got home and readjusted/tightened my throttle cable. Definite improvement in throttle performance, but as expected, did not fix my problem. Still doing a random cough at stop lights when im there for more then 5 seconds or so. And i think its doing it more often now.
What is a good way to test the TPS without buying a whole new TB?
Old Mar 29, 2011 | 07:04 PM
  #22
TRD_Celica's Avatar
did the same felt some improvement but did not fix all, looking to replacing the throttle body all together
Old Mar 29, 2011 | 07:16 PM
  #23
Originally Posted by HS2K007
I will need to search for the thread again. It is simple, look under the throttle body and there is a set screw that determines the resting location of the throttle. Loosen the jam nut and move the screw up until you have the throttle right where you want it. Tighten the jam nut and you are set.
So this is different then the throttle cable adjustment? Today I just adjusted the throttle cable. Theres two nuts there allowing the cable to tense up or slack and i got it to where the cable is tight but not pulling the throttle, giving me better throttle response.
Are you saying there is another adjustment under the TB? Or are we talking about the same thing?
Old Mar 30, 2011 | 09:29 AM
  #24
This random hesitation is definitely getting worse. I am going to run fuel cleaner and check my plugs tonight. Any chance I might have a clogged catalytic converter or something? im stumped.
Old Mar 30, 2011 | 10:14 AM
  #25
MasterForce's Avatar
that might be the problem...when i was getting that my car would act horrible. after trying everything i gave up. couple weeks later a CEL popped up for the cat. bought a test pipe and viola!! runs much smoother and hesitation went away. not only that but i can also be bad gas. i used to get 93 from exxon and i experimented and got 91 from on base and it just got rid of any hesitation during running and any cold starts...
Old Mar 30, 2011 | 11:44 AM
  #26
That's my next step. Tonight ill check the plugs, next time i get gas ill throw in some chevron techron, then probably move towards getting a test pipe (should have one anyway honestly). I'm trying to avoid replacing the entire TB/map/IACV if i can help it.
Old Mar 30, 2011 | 02:38 PM
  #27
HS2K007's Avatar
Two different adjustments. The cable adjustment will only give you a little better throttle response.
Look under the TB just in front of the intake side
There is a set screw with a jam nut under the throttle valve, Loosen the jam nut
Rotate the set screw up, or unitl you hear an increase in rev's
Manually twist the throttle under the hood to let it accuate and settle as if you pressed the pedal and let off
If it still bogs when the throttle settles, move the set screw higher
Repeat these steps until you find the sweet spot so your RPM are not too high but your bog is gone when the throttle drops
Tighten the jam nut once you have no bog and minimal increase in rpm.
Mine is just under 1K,
Old Mar 31, 2011 | 06:23 AM
  #28
ZachP51's Avatar
What year s2k do you have?
Old Mar 31, 2011 | 09:12 AM
  #29
I'm wondering the same. I have a 2000 and i didnt see that last time i checked. DBW only maybe?
Old Mar 31, 2011 | 11:40 AM
  #30
slygag's Avatar
It happened to me s2000 2002 I just changed the tps not the whole throttle body,
happy
