Engine Knocking/Rattling
Looks (sounds) like I have the same problem. Changed the oil 1 week ago and immediately started hearing this knocking. I have an '04 with 42K miles on it. I'm planning to start with the TCT then the serpentine belt pulley, but before I started I wanted to ask if anyone found any other causes or fixes for this. Thanks for sharing.
Well I changed the tensioner bearing and the noise is a little better but still there. I still have to change the other bearing on the lower pulley but I don't think that's the problem. I'm just hoping it's not coming from the block. Take off belt and run it for like 20 seconds and see if u hear it.
You mean it might be the entire tensioner piece. Because I just replaced the tensioner pulley. And my next step is the lower pulley with the smooth surface. Both tensioner pulley and other pulley had play. So I'm hoping that was the problem.
I pinpointed it to cylinder #1.. If I disable spark, the knock goes away. If I disable cylinder #2, the knock continues.
https://www.youtube.com/watch?v=gRSi...ature=youtu.be
Time to take the motor apart.
https://www.youtube.com/watch?v=8DoiFdVEqyk#t=76
(Specifically at 1:16 mark, that's the same knocking, just a bit quieter)
https://www.youtube.com/watch?v=FGrPjfhppMQ
Yes, the entire tensioner sometimes fails.
dam I knew I should of just bought the whole thing.
I'm pretty sure my '05 has had it since I got it at 28k miles. Not as loud as yours at 60k , but my gut feeling is its normal. Your car runs OK right--just the noise?
I'd take it to a competent Honda mechanic before diving into any repairs.
