Engine light comes on and then goes off
Old Sep 25, 2008 | 09:13 PM
guedo's Avatar
Default Engine light comes on and then goes off
Lately my engine light has been comin on after I run it, and when I go back to normal driving the engine light will come on, but after a few drives it will cut off or sometimes when I turn it on in the morning to let it warm up the engine light will come back on then when i get somewhere and park it the light cuts off.When the light is on the car still runs fine it idles right at a grand and it doesnt bog at all. I replaced the sparkplugs with NGK's not to long ago and it still does it my friend said it might be my distributor coils..I dont know help me out
Old Sep 25, 2008 | 09:40 PM
Slows2k's Avatar
The car doesn't have a distributor.
We need the code 1st
Old Sep 25, 2008 | 09:45 PM
guedo's Avatar
my bad man I meant to put Ignition coil sry...he said cylinder 1-4i s misfiring and random ignition code popped up , but i dont think its missfiring because it runs fine and wouldnt have been able to beat this crx with a misfire
Old Sep 25, 2008 | 09:54 PM
Slows2k's Avatar
Flashing check engine light while engine is running = misfire bad enough to damage catalytic converter.
If it stored misfire DTC's for cylinders 1-4 then it's misfiring. Which can be caused by many different things.
Old Sep 25, 2008 | 09:59 PM
guedo's Avatar
It doesnt flash though it comes on then a few drives later cuts off, it only happens every once and a while..well what do I do to fix the problem?
Old Sep 25, 2008 | 10:20 PM
Stealth_SUX_'s Avatar
Check Engine lights dont come on for no reason.. Play it safe, check ur plugs and your coils..
Old Sep 26, 2008 | 10:43 AM
guedo's Avatar
well i just ordered coils and plugs they should be here any time now
Old Sep 26, 2008 | 05:54 PM
darkknight1999's Avatar
Go outside and tighten your gas cap. When my dad uses the car and puts gas in it the CEL always comes on because he doesn't get the gas cap tight enough... he's used to his TL... its much easier Mostly because the gas cap needs to be replaced on my car.
Go check it out... might just be an easy fix.
Old Sep 26, 2008 | 06:00 PM
Slows2k's Avatar
Loose fuel caps don't cause misfires.
trackrabbit21
May 7, 2012 12:56 PM
tadao916
Mar 2, 2009 04:47 PM
Apex_AP1
Mar 1, 2008 01:31 PM
me11jh
Jul 22, 2004 05:34 AM
ytyper
Oct 30, 2003 06:18 AM
