Engine mounts
Old Feb 26, 2016 | 05:21 PM
Sgs2k's Avatar
Default Engine mounts
Hi Guys,
I am running a 2008 AP2 with about 33,000 km (20,000 miles).
About 4-5 years ago, a workshop told me that the engine mounts were worn and had to be changed. I have been driving the car and nothing bad has happened since. I didn't know whether what the workshop told me was reliable hence I did not change.
My questions are:
1. How do I know when it's time to change engine mounts?
2. On the average how long do the OEM mounts last?
Many thanks!!
Old Feb 26, 2016 | 05:47 PM
Fokker's Avatar
Inspect them for cracks, if you cannot see any and are not having any odd vibrations from the front of the car then you should be fine. It is pretty noticeable when they have failed. How long they last varies, but they tend to fail relatively early compared to what you would expect out of engine mounts. I've seen some people with at least one failed as early as 50K miles.
Old Mar 1, 2016 | 06:59 PM
imnida's Avatar
+1 with Fokker on inspecting them for cracks. Weathering will look similar to the weathering/cracking on tires.
I'm not sure if the bushings are hydro filled like on the AP1s, though; so looking to see if there are signs of seepage might not apply.
Old Mar 2, 2016 | 08:01 AM
GSteg's Avatar
AP1 and AP2 mounts are the same.
https://www.youtube.com/watch?v=a1VwSdX2eHI (not my video)
I recently changed my engine mounts at 109k miles and they were not torn at all. It's a case-by-case kind of thing so you need to check for yourself.
Old Mar 4, 2016 | 01:43 PM
Jtanaka's Avatar
I have 103k on my 2005 S2k too and the mounts are fine, I was worried about my mounts breaking too since my rear diff mounts recently leaked this month . Throwing some innovative diff mounts this weekend.
Old Mar 4, 2016 | 02:37 PM
Slowcrash_101's Avatar
It's all in how the car has been driven, hard launches and not using heel and toe will make short work out of all the mounts.
Old Mar 4, 2016 | 03:48 PM
Chris_Lum's Avatar
it's very easy to tell when the engine mounts are toasted because there will be orange fluid leaks all over it (if fresh) or dried brown streaks (if leak is old). The top part of the mount will be separated from the bottom part, but it might not be readily noticeable. just check for the fluid leaks. same goes for the rear diff mounts.
TechyGirlS2k
Sep 28, 2015 08:24 PM
jWESTFOO
Feb 12, 2014 12:30 PM
bigbadben
Car Talk - Non S2000
Oct 26, 2006 03:03 AM
Ringwurm
Nov 8, 2003 03:34 PM
patrick93
Oct 12, 2003 06:07 PM
