Engine Noise Normal WOT & UP TOP?
Old Sep 22, 2010 | 02:58 PM
thesilverbullet's Avatar
Default Engine Noise Normal WOT & UP TOP?
is the "non-smooth" engine noise normal at WOT and high rpms?
i have a fujita cai and q300 exhuast and the engine is strong but on the high cam from 6k+ the engine does not have a smooth/clean note. normal or valves? valves are smooth as silk at idea and normal driving.....
every other condition even WOT on the low cam its clean - it's just up top and at WOT.. with the N1 single it was making an extreem raspy sound, but now with the super quite q300 it sounds like coming from the engine...
Old Sep 22, 2010 | 03:22 PM
seoul2k's Avatar
maybe ur vtec solenoid is effed up? im not sure when vtec kicks in for ap2s but on ap1s vtec kicks in at 6k so if its good on idle and at wot in the low rpms i don't see why your engine would be messed up only at wot at 6+. if urs is a 2007 it might still be under warranty or if you have flash pro maybe the tune effed it up also.
Old Sep 22, 2010 | 03:23 PM
PWRMKR's Avatar
A Hondataflashpro issue because of the hardware changes.
Old Sep 22, 2010 | 04:31 PM
noise was before flashpro....
Old Sep 22, 2010 | 06:19 PM
still studying this - starting to think its the exhaust or heat shields near the header/tp or tp/mid pipe area. its only seems to happend at wot or maybe when the engine is in the most "torque tilt"postition...
P 1
Jul 24, 2011 12:12 PM
Pinchy
19
Feb 18, 2009 07:49 AM
QUIKAG
Jul 16, 2007 10:18 AM
WRS2K
25
Feb 21, 2007 07:48 PM
silencertk
Jun 10, 2006 04:56 AM
