Engine noise problem.
Old May 16, 2012 | 09:04 AM
SammyT's Avatar
Default Engine noise problem.
Hi Guys,
i started my s2k engine week ago and i noticed there's a noise coming from head/exhaust and it started to go higher and conistant now ,it's very noisy,i thought i had bad valve adjustment so i adjusted them(they werent really off the spec,then installed the valve cover back and still have the noise. now i am worried about my rod bearings i never heared such a sound,i replaced the oil it seemed fine,the car had little oil loss(less than 1 quart) and i cut the oil filter and there was no diposetes.
the sound is noticable at idle and part throttle cruise up to 4000 rpm,after that you cant hear it,but the engine sound is not smooth as it should,also car performance is not reponsive as old times.
i took a video for it hoping someone can understand my problem and help.
http://www.youtube.com/watch?v=g5aP3lZMfFE
Thanks in advance.
Old May 16, 2012 | 10:56 AM
SammyT's Avatar
please someone show up and help
Old May 16, 2012 | 11:51 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
sounds like an exhaust leak. possible crack in the header. That would explain the power loss also.
Old May 16, 2012 | 12:29 PM
SammyT's Avatar
Thanks Billman,
you are legend
thanks again for taking care of my issue.
Old May 16, 2012 | 12:43 PM
SammyT's Avatar
because billman answered we had 49 views
Old May 16, 2012 | 02:05 PM
INDYMAC's Avatar
Aftermarket header bolts usually need retorqued/tightened periodically. I would start there.
Old May 16, 2012 | 02:38 PM
SammyT's Avatar
i remember i locked them well because i was replacing my clutch,havent seen crack but i will look again hoping it's just crack the sound is really weird.
liquid_helix136
Sep 28, 2013 09:13 AM
Suvs
Aug 24, 2012 04:44 AM
bjt1ngle
May 18, 2011 02:51 PM
revto9k
Jul 11, 2009 07:21 AM
ItalianBucwheat
Jun 25, 2006 08:50 AM
