engine oil change..
Old Oct 13, 2008 | 09:02 PM
skeithr's Avatar
between the low and high is one qt. dont use an accord filter use the one designed for the s2k, as for oil i would recommend using syn. if you have less than 70k, i like amsoil or redline. its more expensive but worth it. no ac delco, some people on here dont like the mobil one either
Old Oct 13, 2008 | 09:03 PM
skeithr's Avatar
i go through about 1.5 qts per 7500 miles ap1's just burn oil because the jets spray more oil during vtec. not a bad burning oil, just the design
Old Oct 13, 2008 | 10:07 PM
NFRs2000NYC's Avatar
Originally Posted by ikeyballz,Oct 13 2008, 11:51 PM
^WHUT? i think thats wrong. if you have 3x's to go, dont put in 3 quart.
It wasn't exact. You add oil until all the X's are covered. When I was 3 quarts short, I was 3Xs off the H.
Old Oct 14, 2008 | 06:24 AM
Mike in Atlanta's Avatar
You were driving your S2000 when it was low on engine oil by 3 quarts????
Old Oct 14, 2008 | 11:52 AM
s_d2k's Avatar
no way 3 X's is 3 quarts
i was down 3 X's and added almost a quart and the oil went up and cover all the X's
about the oil filter i didnt try it yet maybe in the end of the week , but i think it should fit and it also a little bit smaller..
i read here that some of the turbo guys use a smaller filter , whuch one they use?
Old Oct 14, 2008 | 11:53 PM
21337R's Avatar
I AM SORRY BUT THIS IS ABSOLUTELY IDIOTIC....... HOW THE HELL ARE YOU A MODERATOR? BAN YOURSELF ASAP.
Old Oct 15, 2008 | 01:54 AM
TookayS2K's Avatar
I usually try to keep my oil level in the middle of L/H. Usually I just add about 1/5 a quart to get about TWO x's. imo, you're good as long as you are not below "low" or above "high".
jaxxx
Sep 8, 2010 04:41 AM
wang_uk
Aug 16, 2007 02:09 PM
Lunacy
Jan 28, 2003 12:10 PM
1Randyc
Feb 2, 2001 12:36 PM
javaguru
Nov 2, 2000 04:53 AM
