Engine Oil Help!
Old Nov 15, 2001 | 10:47 AM
enzyme's Avatar
Default Engine Oil Help!
I had Stupid PPL at Firestone change my oil. I brought in 6 Quarts of Mobil 1 and Guess what... some Smuck used all 6 Quarts. I maybe my Imagination but VTEC is not as Pronounced and Excelleration seems to bog and less responsive. CAn + .6 quarts of oil do this or is it something else.
Old Nov 15, 2001 | 11:06 AM
Sideways's Avatar
how far up the dipstick is the oil? I use 5.6 quarts at oil change time.
Old Nov 15, 2001 | 11:10 AM
enzyme's Avatar
The dip stick says it's ok. It's right at the "H" line.. Hummm..
Old Nov 15, 2001 | 07:54 PM
xtc@9k's Avatar
It seems like mine usually takes about 5.5 quarts when i change it. If there is any extra in there it will burn off evnentully. I think you'll be ok.
Old Nov 15, 2001 | 11:03 PM
jpotts's Avatar
if the dipstick is not over the limit, you should be good - just make sure you are checking it consistently - do a search - there's been a lot of different comments on checking oil, oil levels, mobil 1 with the s2000, etc. Many people feel it is sluggish after the switch to synthetic. How many miles are you at? I have 4k and did a dino engine oil change at 3k, but have the mobil 1 sitting in the garage to try later.
Old Nov 17, 2001 | 08:28 AM
Michael A's Avatar
I have been following several of the threads about OIL consumption and how one owner actually had engine / valvetrain problems due to low oil.
So I decided to check my oil. When I check it after the car sits overnight the oil level is exactly at the LOW "L" marking on the dipstick.
If I check the dipstick after I have driven the car and let it sit for 15 minutes the dipstick reading is very inaccurate. There are SMALL amounts of oil splashed all along the points between the "L" and "H". There is NO definite OIL level line so to speak of.
My car has 27K miles on it so I would assume that if their where any oil consumption issues it would have stopped by now.
If I where to add a 1/2 Quart of oil how do I know what viscosity to add?
I know the manual states 10w30 but it also recommends 5w40 for cold temps. Are their any issues with mixing different viscosity oil?
Old Nov 17, 2001 | 09:51 AM
spider's Avatar
[QUOTE]Originally posted by Michael A
[B]
Old Nov 18, 2001 | 07:07 AM
Barry in Wyoming's Avatar
I think the manual says to use 5W40 if you plan on starting your engine at temperatures below 0 deg F. That's pretty cold even for New York and Wyoming. I run 5W40 in my '93 Prelude VTEC because it is my daily driver. I keep 10W30 in my S2000, because I only drive it in the winter on days that are above zero.
You can mix 5W40 and 10W30 without any problem, just like you can mix water and milk. You won't have either but something in between, depending on how you mix.
shingojr
Sep 20, 2007 08:21 PM
soundzero
Nov 3, 2003 07:54 AM
Destiny2002
Feb 18, 2003 04:27 PM
Lunacy
Jan 28, 2003 12:10 PM
kki3o
Mar 7, 2002 11:39 AM
