Engine oil question
Old Jul 1, 2008 | 02:10 PM
sokdo's Avatar
Default Engine oil question
does the s2k have a sensor that triggers the check engine light if it is overfilled? i got a check engine light after i changed my oil with 6 quarts. i'm thinking i should have only put 5-5.5 quarts.
any input on this matter would be greatly appreciated.
Old Jul 1, 2008 | 02:34 PM
HankookS2K's Avatar
i dont think there is a specific sensor for overfilling
6 qts? why?
Old Jul 1, 2008 | 02:36 PM
sokdo's Avatar
i was doing a search topic on oil changes and most said to put around 6. it triggered a check engine light on my 04 so i was just wondering. i put 5 in this time and checked the oil level and seems to be at a perfect level with no check engine light.
Old Jul 1, 2008 | 02:49 PM
teanza's Avatar
so did u put in 5 or 6 this time
~tina~
Old Jul 1, 2008 | 06:14 PM
bat711's Avatar
5.1 is what is supposed to be drained and replaced during an oil change. However, you should be checking the level after you fill to make sure you are in the "X'd" area on the dipstick. If it's above the H mark back the drain plug out a bit and let some out.
People using 6 might be doing a bit of a flush before refilling.
Old Jul 1, 2008 | 11:54 PM
sokdo's Avatar
i put in 5 this time and checked it after warming it up. it's pretty much dead center between the high and low point of the dipstick. seems like everything is all gude now =)
Old Jul 2, 2008 | 02:47 PM
roflitzjinno's Avatar
youre able to put in 5 exactly and have it between the H and L? hmmmm i put 5qts in mine and it was on the H to above it after letting it sit over night..
Old Jul 2, 2008 | 06:14 PM
frofro24's Avatar
I think the sensor is called the dip stick. As per the step by step directions in the owners manual, you car takes 5.1 qts.
han racer
Nov 5, 2010 08:39 PM
ff_mark
Oct 23, 2006 05:53 AM
Danfotoman
Mar 21, 2006 12:33 PM
850glt
Apr 20, 2004 11:14 AM
