engine oil top off question
So here's my question guys don't bash on me, I got my s not too long ago and the oil was freshly changed so I didn't bother with it, well my maitainance light came on and I was going to do an oil change but our jack in my dads work truck at work so I can't do it until the late afternoon, so I thought I could just top off the oil a bit without draining it just to be on the safe since ap1s burn so much oil, I would rrally hate to starve my engine. Now my question, is there some sort of indication on the fill port other than just the dip stick cause I've never been too good with those. Am I suppose to be able to see oil thought the fill hole? When I look in there all I see is the shafts or whatever they are but no oil in sight. Also my was engine cold when I checked if anything has to do with it. So how do I just top off the oil to be safe? And dont get me wrong I'm still going to do the full oil change when I get the jack but I want to make sure I have oil in there because I have something to do later and its my only ride. Thanks!
you dont need to do an oil change if it was just changed...that light is disigned to come on at certain intervals..the person who did the oil change just didnt reset the light...and no theres no indication other than the dipstick and no you shouldt see oil through the fill hole...oil sits in the oil pan and sucked up through the oil pickup...typically if the oil is at the bottom of the dipstick i put about a quart in it...just add it slowly and keep checking the dipstick so you dont overfill it
To use the dipstick correctly I would let the car sit more than an hour, then use a clean paper towel to clean the dipstick. Put the dipstick back in and check a few times until the same amount show up at the same spot on the dipstick. Then I will add the oil depending how much it needed.
If yours is like mine, one side of the dipstick will get oil way up on it, but the other side will show the true level. Pull the dipstick and wipe the end with a paper towel, then reseat it. Pull it back out and look at both sides to see which one has a nice line of oil across it, hopefully across the XXXXXX section. It's especially hard to see when the oil is still clean after a change. Practice!
http://techinfo.honda.com/rjanisis/p...707O00110A.pdf
There's nothing unusual about oil changes or checking the oil level with the S.
Eventually he should learn to do it. It's one of life's essential skiills IMO, like simple cooking and managing money, every guy should know basic auto maintenance. The first time I did an oil change I was 14 years old and read, re-read and double checked the Chilton manual for my dad's car a dozen times. Just be careful and get an experienced buddy to help if possible.
