Engine Problem
Old May 1, 2008 | 04:42 AM
clag's Avatar
S2Kart it sounds like a different issue, nice job on fixing it.
The heat bog is not unusual and after getting to know the car you will feel it coming. You give a little gas and the car does not respond, more throttle just means it will lurch once it gets it's breath and the pogo begins. If you feel the throttle go numb, just hold position and it will catch up, don't add more or it just gets worse. Once I feel that dead spot on the throttle I go to neutral and run it up to 3k or so, pulling fresh air into the box for a couple seconds. It is usually fine when I go back to first. I use the same technique for autocross starts in Georgia and Florida after it bit me a couple times waiting at the timing lights. You will start to anticipate this in certain situations, hot weather, stop and go, then you can address it before the embarrassment begins.
Old May 1, 2008 | 06:42 AM
Saki GT's Avatar
Sounds like the MAP may need to be cleaned, replugged in.
Old Jun 17, 2008 | 08:14 PM
TRBOKEV's Avatar
Interesting. I will have to try carts check myself. The last tow days I seem to be having the same problem.
Old Jun 20, 2008 | 06:18 PM
Simon X's Avatar
exactly the same problem here...
I bought the car a month ago and I tought I was the problem
But now i'm not so sure...
At first I was sure it was my fault.. bad shifting or something like that.
but I realized that this problem is not happening when shifting gears..
When you start (ok)
shift in 2nd (ok)
accelerate (ok)
remove you foot on the gas pedal (ok)
then reaccelerate (There is the bucking action!!)
Old Jun 20, 2008 | 07:28 PM
slalom44's Avatar
Top Answer: 1
Originally Posted by Simon X,Jun 20 2008, 09:18 PM
When you start (ok)
shift in 2nd (ok)
accelerate (ok)
From my experience, heat bog usually only happens in first gear at relativelly low speeds when you let off the accelerator, then reaccelerate. If you're getting this in second gear, you might have another problem.
So you have tried wedging your foot against the carpet next to the gas pedal as I suggested above and this still happens?
Old Jun 21, 2008 | 07:14 AM
Simon X's Avatar
I'll try that today
If its not my fault (I hope it is)
Its probably a heat bog...and it happens on the first and 2nd gear
when lifting up the accelerator and then reaccelerate.. like you said
Yesterday it happened in first gear...at the start..
Maybe I engaged the clutch too slow like Ludeboye1 said
Old Jun 21, 2008 | 03:44 PM
Simon X's Avatar
did 100 kilometers today
on speedway ,trafic jam, high speed low speed ect
the problem never happened.
But there was no humidity in the air today.
I've noticed that everytimes the problem happened the humidity in the air was at a high level.
maybe my S2000 is fragile to the cold and humidity h
jeremicium
Feb 5, 2014 02:23 PM
AwesomeMan
Sep 30, 2008 08:06 PM
GazS2000
Jan 16, 2008 09:19 PM
SpeedyG05
Apr 10, 2006 08:20 PM
passleft
Oct 11, 2001 10:49 AM
