Engine Problem
Old May 29, 2008 | 04:19 PM
Blacknizzle69's Avatar
Default Engine Problem
I have a 2001 S, and I was wondering wat could cause some of these problems im having. It consumes and burns a lot of oil and will occasionally smoke burning white smoke while im at a stop light and pulling off from a red light. Someone please help me with this problem. My friend down at UTI in Orlando said that one of my piston rings could be bad and I need to get a compression test done.
Old May 29, 2008 | 04:31 PM
ian05s2k's Avatar
does the white smoke smell sweet? If it does you most likely have coolant leaking into a cylinder. Also, what do you mean by burning a lot of oil? As in how much and how often do you add oil. The ap1s to tend to burn oil.
Old May 29, 2008 | 04:56 PM
tunermt's Avatar
if it smokes right when you start it up and it white (steam) its coolant oil will be kinda blue and smell like a old motor boat. compression test would be good, you can do a little sniffer test for exhaust gas in the coolant (napa sells the kit) it could be valve guides how many miles are on it?
Old May 29, 2008 | 05:28 PM
It has 71000 on it and just had a recent tune up done.
Old May 29, 2008 | 11:02 PM
jyeung528's Avatar
you've got a problem, perhaps coolant leak
you should do a leakdown test.
Old May 30, 2008 | 01:34 AM
howardtan's Avatar
Check for any holes on the radiator, as well.
RedStarS2K
May 24, 2013 11:36 AM
RangOs2000
Dec 28, 2008 07:14 PM
PaulF
Oct 31, 2008 12:00 AM
sbabys2000
Apr 9, 2008 11:48 PM
llxzxll
Jan 24, 2008 12:36 AM
