Engine problem after engaging Vtec
Old Aug 28, 2012 | 09:49 AM
skyteg's Avatar
Default Engine problem after engaging Vtec
hey, so i have a MY2000 with 98000km i was shifting from 2nd to 3rd gear at 7000rpm, as soon as i floored the 3rd gear engine cut for a second, and speed kept going down i couldnt accelerate. Simultaneously the check engine light kept flicking. Put it in 6th gear to lower rpm and starting accelerating slowly and was ok. Stopped the car and had no CEL code. Started off again shifted my gears at around 3K rpm, made it in 6th gear. While i was running 105KM my speedometer started incidcating that my speed was dropping but it wasnt, and suddenly it flashed back at the right speed...
What the hell could this be??
Old Aug 28, 2012 | 11:23 AM
4forall's Avatar
If you have low oil Vtec will not engage or it will disengage if the oil pressure ever gets low while in Vtec. I would start there.
P.S.- Do not skip shift (aka go from 3rd to 6th gear) this has been known to cause the syncro on 5th/6th gear to get burred up and can cause some issues getting into those gears.
Old Aug 28, 2012 | 12:44 PM
starchland's Avatar
cel was flashing? dont keep driving it. what was the cel?
Old Aug 28, 2012 | 06:19 PM
xviper's Avatar
How do you know there's no code? Did you have a scanner with you? If the CEL came on, even blinked, there's a code in there. Find out what it is.
Old Aug 28, 2012 | 06:46 PM
skyteg's Avatar
hey guys, yeah had a scanner with me! finally it was the ground on the cylinder head that was loose. thx alot!
Old Aug 28, 2012 | 07:49 PM
CoolGuy094's Avatar
I was about to suggest that... billman made a post about it in a different thread yesterday.
Old Aug 28, 2012 | 08:05 PM
xviper's Avatar
Bad ground = momentary battery disconnect = ECU reset. I would have thought that more than just the CEL would flicker. Other dash lights should flicker as well.
Old Aug 28, 2012 | 11:16 PM
s2k-tilldeath's Avatar
Wow, that is weird. I've never heard/seen that before. Damn. Glad everything is okay with your S.
dyhppy
Sep 15, 2008 09:23 AM
PathNull
Nov 16, 2004 08:28 PM
BlitzSRM
Feb 2, 2004 08:16 PM
tagheuer
Sep 2, 2001 06:11 PM
Pinky
Apr 4, 2001 08:07 AM
