Engine removal Q
Old Sep 22, 2009 | 07:36 AM
S2K2GO!!'s Avatar
Default Engine removal Q
Can someone tell me if the entire engine/tranny assembly be removed and installad with header and induction manifolds in place? (search is down again ) Thanks-
Old Sep 22, 2009 | 07:55 AM
dammitjim's Avatar
You can use google to search the site like this
"engine removal" header site:s2ki.com
Looks like the intake manifold can stay on and the headers should be removed
https://www.s2ki.com/forums/index.php?showtopic=550476
Old Sep 22, 2009 | 09:21 AM
TelosHedge's Avatar
the only way to remove the motor and tranny together is to drop the motor out with the subframe from the bottom. there is not enough room to pull the engine and tranny out from the top (unless you pull the head first...)
the exhaust manifold comes off so easily it doesn't pay to keep it on. the intake manifold does not need to come off at all.
Old Sep 22, 2009 | 09:31 AM
supahman04's Avatar
Nope, the exhaust comes out the bottom easily after you drop the front subframe. Do yourself a favor and take the tranny off of the engine.
This thread helped me the first time I took my engine out:
https://www.s2ki.com/forums/index.php?showt...0&#entry1036057
jrlandsman
Apr 1, 2010 11:47 AM
kial007
Dec 26, 2009 07:27 PM
2QYK4U
Dec 19, 2007 04:24 AM
AusS2000
Apr 6, 2007 10:21 PM
duff0000
Apr 4, 2007 04:05 PM
