Engine Shaking
Old Sep 19, 2004 | 06:56 PM
Leg3nda12y S's Avatar
Default Engine Shaking
the cabin shakes when i'm in a couple of gears. it vibrates sort of violently. what i mean by a couple of gears, is it usually only happens in 2, 5, and 6. is there something wrong with the rods?
Old Sep 20, 2004 | 04:44 PM
xviper's Avatar
How have you determined it to be the engine? Bad CVs, bad rear diff, bad wheel hubs can produce a similar cabin shake.
If it were the engine, I would put my money on bad bearings - either crank or rod.
Old Nov 9, 2004 | 09:29 AM
Anrosphynx's Avatar
Ok, I have a similar problem. But only under acceleration. I notice it most in 6th gear on the highway. If i am cruising, it feels fine, but as soon as i try to accelerate, the whole car starts to shake pretty bad. Any ideas?
Old Nov 9, 2004 | 10:48 AM
Boit's Avatar
You might want to check your engine and transmission mounts. I don't see how your description would point to an internal engine problem since those types of problems would usually accompany a knocking noise . . .especially if it were the rods.
Old Nov 9, 2004 | 01:59 PM
pantyraider's Avatar
Is this related to the "shudders" when stopped? I notice when the car has just been driven around (maybe for 10 mins) it'll shudder. Goes away when warm. Sorry if this is completely unrelated to the topic at hand.
Old Nov 9, 2004 | 02:08 PM
mikegarrison's Avatar
The "shudders under acceleration" thing has been definitely resolved: worn CV joints.
Old Nov 9, 2004 | 02:13 PM
esracer's Avatar
I would like to know the same, i have the same thing...
Old Nov 9, 2004 | 02:14 PM
Anrosphynx's Avatar
I will definitely check those.. thanks for the tips guys.. I do not, nor have i ever believed that my problem was engine related.. But i will definitely check the CV joints this weekend..
Old Nov 9, 2004 | 04:05 PM
kane.s2k's Avatar
dont forget the mounts...all of them.
Old Nov 9, 2004 | 10:49 PM
Boit's Avatar
Sorry.....I should have made it clear that my response was directed toward the orginal poster.
