Engine Splutter
Old Jan 26, 2005 | 06:09 PM
REV_29K's Avatar
Default Engine Splutter
I tried to do a search about why my car idles funny and also the exhaust sounds like its spluttering but i couldnt find anything
Could anyone help with this as its driving me crazy???
This may sound silly but is it bad that in the morning when i start my car, it spits out alot of water from the exhausts???
Please help!!!
Old Jan 26, 2005 | 09:01 PM
xviper's Avatar
The water is just condensation that is a product of combustion. Once the exhaust system heats up, this water stays in the gaseous form it started out as rather than "condensing" into a fluid. It is normal.
As for your other questions, I'm not even going to touch those with a barge pole. "Idles funny" and "spluttering" are NOT very objective descriptions and could be interpretted as almost anything.
Old Jan 27, 2005 | 09:49 AM
Bigsalgt's Avatar
, That can be anything from a bent valve to a bad ECU! More details are needed for any type of diagnoses!
Old Jan 27, 2005 | 11:57 AM
REV_29K's Avatar
I tried the MAP whack sensor trick and reset the ECU but it didnt stop the rough idle. The idle goes to and from 1000 rpm to 800rpm (back & forth). Its as though i have got very big lumpy cams in the car but it is absolutely stock except for the K & N filter...
Old Jan 27, 2005 | 12:14 PM
xviper's Avatar
A fluctuation of 200 rpm at idle is not anything to be concerned about. It could still be a bad MAP or it could be something sticking with the Idle Air Control. It could be valve adjustment issues, ECU issues, fuel pressure issues, vacuum leak.
I've had full race cams on a muscle car. "Lumpy" would be a fluctuation of over 500 rpm. 200 rpm at idle over a 9000 rpm range is not yet a problem.
Old Jan 27, 2005 | 04:32 PM
REV_29K's Avatar
Cool thanks for the input Xviper. It puts my mind at ease that my car is not gonna break down on me since i only just got it about 5weeks ago.
seoul2k
Mar 17, 2011 12:02 PM
A.VOID
Jul 12, 2010 05:53 PM
mumbler
Jul 17, 2006 10:36 AM
sjs2k4o8
May 9, 2006 11:15 AM
Denniz
Aug 26, 2004 10:00 AM
