Engine squeal at startup
Old Mar 29, 2014 | 10:32 AM
OMCMT's Avatar
Default Engine squeal at startup
This happens in the morning after the car has sit in the garage for 10-12 hrs and appears to happen at either warm or cold mornings.
I push the start button and the engine makes a squeaky/squeal like sound. Anybody able to provide advice on this issue?
Old Mar 29, 2014 | 10:52 AM
realblag's Avatar
Remove the serpentine belt and start the engine. You probably have a pulley bearing going bad. If so, you won't have the squeal and the belt will already be off so you can check the pulleys.
Old Mar 31, 2014 | 08:45 AM
Anastasia Beaverhausen's Avatar
If it is a pulley bearing, what are the consequences of not changing it? Continued squeal on start-up or something worse?
Old Mar 31, 2014 | 10:19 AM
dakao's Avatar
If it is only making the sound at startup and goes away after couple minutes then I think it's just your drive belt is too old...
If it is the pulley bearing then it will be noisy all the time... my 2 cents...
Old Mar 31, 2014 | 11:14 AM
Slowcrash_101's Avatar
Could be your starter as well.
Old Mar 31, 2014 | 11:42 AM
jimi's Avatar
Somethng worse
Old Apr 1, 2014 | 09:02 PM
OMCMT's Avatar
Yes it only makes it at startup and it's only for a few seconds...2 to 3 secs. It goes away immediately after that and doesn't linger.
Old Apr 2, 2014 | 06:26 PM
Car Analogy's Avatar
There is a startup squeel that is normal on the S. But it usually only happens when its cold out. But my car has done it in temps above 45. I believe as the starter wears it becomes more prevalent.
Old Apr 3, 2014 | 08:42 PM
Utah S2K's Avatar
Replace your belt.
I love these threads. Please keep up the responses guys as they are priceless!
Utah
P.S. I use a Goodyear Gatorback from Summit Racing....P/N: 4060578
Old Apr 3, 2014 | 09:13 PM
gptoyz's Avatar
what if the belt is new and in spec?
