EPS issue that won't reset
Old Sep 3, 2019 | 11:31 AM
cyprinus's Avatar
Default EPS issue that won't reset
Hi All,
The EPS light came on on my 2008 S2K on Saturday.
I've had a good dig through here and tried the reset procedure, both shorting the SCS connector and pins 4 + 9 on the OBD connector. Both methods just cycle through three fault codes, the reset procedure doesn't even start.
The codes are: 3, 23 and 34
34 (main microcomputer) looks bad to me!
There's no power at the multi-plug on the power steering motor.
I'm planning to take out the battery and control unit tomorrow night to clean up contacts and maybe even a little "percussive maintenance"
Assuming that doesn't make any difference, I was then going to look for a replacement on eBay. I'm a little unsure as to what to look for in terms of model number.
I've attached a (dodgy) picture of the label from mine.
Which if these should I look to match from an eBay part?
Thanks in advance
Mark
Old Sep 3, 2019 | 01:38 PM
Chuck S's Avatar
EPS UNIT
This Fits Your 2008 Honda
Part Number: 39980-S2A-A05
Supersession(s): 39980-S2A-A04; 39980-S2A-A03; 39980S2AA03; 39980S2AA04
You may be able to find the OE part (Honda didn't make this). New part retails for over $1000 so Ebay would be the place to start.
Got the service manual? Throwing multiple-hundred dollar parts at the car very frequently doesn't fix it.
-- Chuck
Old Sep 3, 2019 | 06:48 PM
Longvl85's Avatar
Originally Posted by cyprinus
Hi All,
Thanks in advance
Mark
I found that if you don't turn the wheel to 45 degree and hold it there the process doesn't start. Just got done work through a few eps codes myself.
Old Sep 3, 2019 | 06:49 PM
Longvl85's Avatar
I had code 3 and 23. I replaced the eps module and that cleared code 23. Code 3 I had to replace my steering rack after diagnosis.
Old Sep 4, 2019 | 12:44 AM
cyprinus's Avatar
Chuck,
Thanks for the quick response!
When you say supersession, do you mean that the A04 won't work? I've found two of those on ebay quite cheap, but no -A05's on there at the moment.
I haven't got the service manual. I have had a quick dig around, but can't see how to get a copy for a 2008 UK model. Any ideas?
Old Sep 4, 2019 | 12:46 AM
cyprinus's Avatar
Longvl85
I'll try again after I've refitted the EPS ECU.
There's quite a camber on our road, maybe I'll head off to a nice flat carpark somewhere.
Old Sep 4, 2019 | 08:59 AM
cyprinus's Avatar
After removing and refitting the ECU, I managed to get the reset procedure to complete.
Just code 3 left now.
Old Sep 4, 2019 | 02:17 PM
Chuck S's Avatar
Superseded merely indicated the old part number is revoked and this is the current and correct number. Older parts should work.
This is a link to the US/CDA Service Manual. Other than your steering wheel being on the wrong side of the car I can't imagine the trouble shooting of the EPS system will be different.
-- Chuck
vicrc
May 15, 2019 06:03 PM
steevie_7
Jun 3, 2018 07:34 AM
akesh45
May 23, 2018 12:48 PM
AwdSon
May 22, 2018 03:50 AM
