EPS not working, no light on
Just re-located my EPS unit and now it doesn't work. No bulb check when key is turned on, and no light on for code set.
Another problem that happened at the same time is the tach no longer works (the speedo does however).
It seems like I've crossed wires or something but I've triple checked the drawing I made before I de-pinned the connectors and they are the same.
I would assume if there was a problem with my wiring there would be an EPS code but like I said, it doesn't even come on to do the bulb check.
Maybe someone has a connector pin-out diagram I could re-check with?
Car is AP1, 2000.
edit: oddly enough I just noticed the lock button on my key fob doesn't work either (the light flashes on the fob but nothing happens. All other buttons work). Not sure if it's related.
I guess I'd just really like to know with the wires on the 14 pin EPS connector are for.
Car is AP1, 2000.
