EPS stopped working
Old Nov 13, 2011 | 08:44 AM
Luke_sedz's Avatar
Default EPS stopped working
Hi,
I am running an S2000 with a custom engine swap. I have the speedo working but no EPS and the EPS light is on.
What I have done to get the speedo to work is wired from my swap engine directly into the back of the cluster C-3 (VSS IN) and cut the old wire out.
Also I am not sure if the EPS needs the tacho but I have done the same with this and it works, ran a wire straight in to C-5 (Tacho in) ad cut the old wire out.
The car is a 2000 AP1.
Do I need to put any signal to the S2000 ECU or does a signal come from the back of the speedo cluster? Also if it does which wire does it come out on?
Thanks
Old Nov 13, 2011 | 04:33 PM
Stratocaster's Avatar
The VSS connects to the ECU, the ECU connects to the speedo, and the speedo connectors to the EPS.
Old Nov 13, 2011 | 10:26 PM
Luke_sedz's Avatar
So how does the speedo connect to the eps? Do you know the pin out as I can't see any vss-out pins.
Thanks.
Old Nov 15, 2011 | 01:46 PM
Luke_sedz's Avatar
Anyone?
Old Nov 15, 2011 | 03:21 PM
xyster's Avatar
Connector C at cluster (black) pin number 1 white/black wire (vehicle speed pulse output) 2000-2003 model car
Pin number 3 blue/white wire is (vehicle speed signal input(-))
Pin number 5 blue wire (tachometer signal output)
Bibbs
Feb 28, 2006 04:49 AM
chris@vortech
Aug 26, 2005 09:29 AM
johninator
Jan 30, 2004 04:25 PM
Asura
Feb 26, 2003 09:11 AM
BlackS2000Turbo
Aug 19, 2002 05:00 AM
